test test test
Advice needed - Dr. Carlos Wesley or Dr. Hasson & Wong for FUE?
You’re in a good position with both options for sure! I went with Dr. Hasson & Wong as well, and while I had a positive experience overall, I did notice that the post-op guidance wasn’t as thorough as I would have liked. I think it's crucial to have open communication for any concerns that pop up afterward. On the flip side, I heard Dr. Wesley gives you that personal touch, which can be super valuable. One thing to consider is how much time you can dedicate to travel for follow-ups; Hasson & Wong has more established remote support if you're not based nearby.
Also, I’d recommend checking forums for photos of actual patients from both doctors to see the results that match your goals. And have you thought about using medications like finasteride or minoxidil post-op? I’ve seen quite a few patients combining those with their transplants, and they seem to boost overall results.
  • Odpowiedzi 32
  • Wyświetleń 624
  • Dodano
  • Ostatnia odpowiedź
Najlepsi użytkownicy w tym temacie
So, I think both doctors have their strong suits, but if you're leaning toward Dr. Hasson & Wong, I'd recommend maybe looking into their experience with your specific hair type. I’ve seen some reviews mention that they excel with finer hair, which could be relevant if you have that kind of texture. On the other hand, if you have coarser hair, Dr. Wesley might be a better fit for maximizing density.
I also think it’s worth considering the post-op support. I’ve heard Dr. Hasson & Wong does have check-ins after the procedure, but perhaps not as much one-on-one time compared to Dr. Wesley. Just my two cents, but you might want to ask both clinics about their follow-up process and see which aligns more with your expectations.
Have you thought about the recovery timelines? From what I gathered, patients from Dr. Wesley often report faster healing times, but it might vary based on individual cases. Good luck making your choice!
Choosing between Dr. Wesley and Dr. Hasson & Wong can be tricky! I actually met with both before making my decision. One thing that stood out for me was Dr. Wesley’s use of the latest FUE technology, especially his emphasis on graft handling, which can really boost survival rates. I did 3500 grafts with him about 6 months ago and paid around $7000. So far, the results have been amazing, and I haven’t noticed any complications at all!
Another thing to consider is the recovery process. I found Dr. Wesley’s post-op care instructions to be super detailed, which made my healing much smoother. I’ve heard from some friends who went with Hasson & Wong that while their results were good, they had a bit of a rough time figuring things out after the procedure. It really depends on what you're most comfortable with. Have you thought about how much support you might need post-surgery?
It’s a tough choice for sure! I had my FUE with Dr. Feriduni in Belgium, but I've followed the results from both Dr. Wesley and Hasson & Wong closely. Honestly, I think a lot comes down to personal comfort and trust with the doctor. Have you considered reaching out to patients from both clinics for their before-and-after photos? That could give you some visual insight into each doctor's results.
Also, don't forget to think about follow-up care. I’ve heard that Dr. Wesley tends to have a strong post-op plan, which can make a difference in recovery and overall satisfaction. By the way, if you’re planning to use finasteride or minoxidil after the procedure, that can also impact your results in the long run.
Good luck with your decision!
Honestly, both options are solid, but I think it also depends on what kind of aftercare you’re looking for. I went with Dr. Rahal in Ottawa for my FUE a year ago, and while his technique was great, the post-op support made a huge difference. I remember reading that Dr. Hasson & Wong have a pretty good follow-up program, while Dr. Wesley may focus more on the initial surgery itself. If you can, maybe consider reaching out to patients who've had recent work done to see how their healing process went.
Also, have you thought about financing options? Dr. Wesley had a payment plan that made things easier on my wallet, which was a big plus. Good luck with your choice - it’s a big step, but definitely worth it in the end!
Hey! I totally get how overwhelming this decision can be. Just to add my two cents, I went for my FUE with Dr. Hasson & Wong about a year ago, and I was really impressed with their pre-op consultation process. They took the time to go over everything in detail, which made me feel way more comfortable. I ended up getting 2800 grafts, and I paid around $6500.
One thing I loved was their commitment to patient education. They provided me with a detailed recovery plan that included tips on medications like minoxidil and finasteride, which I think are super important for maintaining results. I've seen solid growth so far, and I'm really happy with how everything turned out. So if you value that type of support and guidance, I’d lean towards Dr. Hasson & Wong. But ultimately, it’s about finding the right fit for you!
Choosing between these two can be a real maze! I've done a good amount of research on Dr. Carlos Wesley and Dr. Hasson & Wong, and one thing that stood out to me is the technology each clinic uses. Dr. Wesley is known for using some advanced tools in his FUE surgeries, like the ARTAS robot, which can improve precision. On the other hand, Hasson & Wong have a fantastic reputation for their artistry in hairline design, which can really make a big difference in results, especially for a NW4 like you. Have you considered how important the aesthetic outcome is for you vs. the surgical tech used? Also, since you're looking at 3000 grafts, don’t forget to check if they offer any financing options if that’s a concern. It can help make it a more manageable expense!
This is a tough choice, but it might help to think about your long-term goals too. I went to Dr. Feriduni in Belgium and he emphasized the importance of crafting a natural hairline, which really stuck with me. I believe both Dr. Wesley and Dr. Hasson & Wong can deliver excellent results, but the artistry in hairline design can vary. Have you checked out any before-and-after photos specifically for hairlines from both clinics? Also, you might want to consider travel costs if you're coming from out of town, as that can add up. I ended up spending around $5k with Dr. Feriduni and felt it was worth every penny. Just keep in mind that results can depend on individual factors too, like your hair quality and how well you're healing. Good luck with your decision!
Jeśli chcesz dodać odpowiedź, zaloguj się
Komentowanie zawartości tej strony możliwe jest po zalogowaniu
